Help! Metal Studs
  • MilDoc
    Help! Metal Studs
    My NCOIC asked me to build a small, lockable box to hold money put in for "snacks" in our clinic. No problem. Easy to build, easy to lock.
    BUT, the walls are typical office walls with metal studs. So...
    how to attach the box securely to metal studs????
    Toggle bolts? Some screw or fastener I've never heard of? Or...?
    • 22106
    Sheet metal screws. Should be able to find them at the local hardware stores.
    • LJR
      • Jan 2005
      • 136
      If I were doing that I'd use toggle bolts. If you can catch the flange of the stud and drill through that and let the toggle wings expand out so they catch on the metal it will make it a bit more secure. Good luck.
        Try to get the self tapping kind. As they are driven in try not to overtighten as that will strip out the stud.
        A THING OF BEAUTY IS A JOY FOREVER - John Keats
          • 22106
          I think all sheet metal screws are self-tapping by definition.
          I have the chart specifying sheet metal screw size vs. gauge of the metal. From the screw size then you need to drill the right sized hole.
          let us know the gauge or at least the thickness of the metal used for the stud.
            • 22106
            I've done a little more thinking and am not sure about my answer.
            I read that most studs are 22-25 ga. which would mean you want a #10 sheet metal screw with #25 or 26 drill.
            But since the screw is really hanging on by one thread the pull out strength is not going to be real huge. A recommendation was that a #6 screw could hold about 30 lbs. pull.
            Assuming this is a security box some one might try to pry off the wall,
            even 10 screws would might be questionalbe particularly if they pried on one side first.
            Maybe the toggle bolts would be better.
            OTOH steel studs don't have so much bending strength? Maybe its not secure to bolt to a steel stud wall either method, they don't recommend it for large hanging loads. I imagine at some point the sheetrock would fail since that's what gives steel stud walls their strength and rigidity.
            • Cheeky
              • 862
              • westchester cty, new york
              • Ridgid TS2400LS
              like a tv mount, you should drill through the steel stud flange and use a metal toggle bolt. never just drill through the stud with just a screw without backing it. metal studs are substantially weeker than wood.
              i wouldn't use metal toggle bolts for the area you will not be anchoring into the stud (ie through the drywall alone), because they tend to loosen over time and tear the drywall.
              what i would use is an ez drywall anchor....they are awesome. they are available at all hardware and big box stores, in either plastic or metal, and hold upwards of 100lbs (larger size metal).
              http://www.artistcraft.com/assets/images/HI2.jpg
              Pete
                The best way to mount fixtures to steel studs is to install wood blocking between the studs before the gypsum board goes on. This is our standard detail for stuff like grab bars, fire extinguisher cabinets, TV brackets, whatever. Obviously this is not an option with an existing wall.
                So my first choice here would be toggle bolts through the steel studs (i.e., not just through the gyp board). Second choice would be a toss-up between toggle bolts through the gyp board alone, rawl plugs into the gyp board, or sheet metal screws into the studs. Or possibly some combination of two of those. Many times I've solved problems like this by anchoring solidly into a stud on one side and then doing the best I could on the other, if whatever I was installing wouldn't reach to the next stud.
                • MilDoc
                  The box itself will only be 14" in length. Planned on using 2 of whatever, one above the other into the stud. Does have to be well mounted to suit the US Army.
                  • TheRic
                    • Jun 2004
                    • 1912
                    • West Central Ohio
                    I wouldn't worry to much about how strong it's mounted to the wall. Someone is going to get into it one way or another if they really want to. I think what you are trying to do is keep the honest people honest.
                    One could cut thru the bolts / screws with a cordless sawzall. Someone walking around with one of those around the money box is going to draw suspicion. The same as someone walking around with a box that size. Specially when everyone will know what it looks like, and used for.
                    I would be more worried about holding the box's weight when full of coins, and being bumped into.
                    Just my 2 cents worth.
                    Ric
                    • Tom Slick
                      • 2913
                      • Paso Robles, Calif, USA.
                      • sears BT3 clone
                      a "small lockable box" will absolutely be held up just fine with a couple of sheet metal screws in metal studs. my building has a fair amount of metal studs and nothing that I have hung with screws has come out including items much heavier then a cash box.
                        Got a welder? Some metal brackets? Just kidding!
                        • MilDoc
                          Great idea! But the Army would certainly consider it a fire hazard for some reason.
                          • Tom Slick
                            • 2913
                            • sears BT3 clone
                            since it's for the Army you'd better send it out for contract, just to be fair. wait for the budget comitee to ok it then go through the bid process to select a winning bidder. in 2 years a person that is a subcontractor of the winning contractor will send out a guy who has never really done that type of work but the original contractor explained how to do it. he will install it with chinese made screws although the original contract specified american made screws. you won't be able to use the installed cash box because the base inspector won't sign it off because it is not according to contract. you'll wait for 3 more months as the original contractor finds a new subcontractor to come out and replace the screws...
                            • MilDoc
                              ROTFLOL! But true!
