Cutting piano hinge
  • pierhogunn
    • 1567
    • Harrisburg, NC, USA.
    Cutting piano hinge
    Gent's, have a problem
    Hope Chest I want to build is 44" long, Piano Hinge I want to use is 48" long
    how do I make the hinge fit the hope chest?
    Monty Python's Flying Circus
    Dan in Harrisburg, NC
  • bigfoot
    • Sep 2006
    • 86
    I use tin snips, I suppose a cutting wheel on a grinder or a dremel would be more refined, and probably cleaner. Just make the cut to line up in a 'gap' where the hinge pin would be visible.
    The voices made me do it.
    • DUD
      • 3309
      • Jonesboro, Arkansas, USA.
      I think a Dremel tool was the greatest thing invented in times like this. You put in a metal cutoff blade, hold it steady, two halves. Bill
        Hacksaw
        ken
        • Thom2
          • 1786
          • Stevens, PA, USA.
          • Craftsman 22124
          Hope Chest Stretcher
          • LYU370
            • Mar 2005
            • 215
            • Streamwood, IL.
            Does that work on Dollars as well?
            Andy
              My Ex had one of those, but her name wasn't Hope!
              • big tim
                • 546
                • Scarborough, Toronto,Canada
                • SawStop PCS
                I have cut both brass as well as stainless steel piano hinges with a hacksaw!
                Tim
                • wardprobst
                  • 681
                  • Wichita Falls, TX, USA.
                  • Craftsman 22811
                  At last, something I know something about- hacksaw, 32 tooth blade, preferably in a miter box to keep the cut square. Fine file and polish the cut end.
                  DP
                  www.wardprobst.com
                  • eezlock
                    • 997
                    • Charlotte,N.C.
                    cutting a piano hinge....
                    I wrapped mine in a shop rag clamped it in the bench vise and cut it with a
                    fine tooth hacksaw, then filed the cut edge and cleaned it up...works
                    great. eezlock
                    • Tequila
                      • 684
                      • King of Prussia, PA, USA.
                      I've always used a fine tooth hacksaw to cut it, and a quick trip to the grinding wheel to clean up the edges.
                      -Joe
                      • pierhogunn
                        • 1567
                        Okay, so here is what I believe the consensus is for the order of operations
                        1. place piano hinge folded flat with the pin towards the top in a non-marring vise
                        2. carefully cut hinge to length
                        3. clean, file and polish the cut edge
                        4. go have a cold adult beverage
                        sound about right?
                        • TheRic
                          • Jun 2004
                          • 1912
                          • West Central Ohio
                          I know 4 is correct!!!
                          Ric
