Looking for some hints or links to plans for a stereo equipment cabinet that I can use to help me finalize my plans. I've been searching, but so far nothing quite right has popped up. Most cabinets incorporate the television or are huge things designed for a space I don't have. I actually need a small cabinet, as the television is firmly mounted to the wall, and I want everything to be "hidden", even if the cabinet is technically in plain view.
Basically I want it to sit in the corner of the room, behind a speaker. I have about 5sqft to play with, and I have 6 components (various amps, receivers, xbox etc). Max width is 20" for the components, with a similar depth. Shelving does not need to be adjustable, as I am planning on customizing it to the proper setup for each component (i.e. tallest is about 6", but the dvr is only 3", and I will give it another inch or so for heat spacing). For heat I am planning on putting two outward facing fans on the back of the cabinet, running at very slow/inaudible speeds, with slots cut in the bottom towards the front to minimize appearance and noise (xbox 360 is loud). Shelving will have 2-3" gaps between the front of the cabinet and the back, easy to run cables and allows for airflow.
I do not need a glass front or anything like that for the remote, as I will be using an IR repeater to get signals into the cabinet. Unfortunately there are no closets in easy reach, so I can't just throw everything in there and run long cables.
BTW: I am a total newbie at this, and probably biting off way more than I can chew I have built a bunch of "functional" speakers in my past. Ugly as sin but I doubt a grenade would dent them. I have a bt3100 (obviously), a router (ryobi), a PC circular saw, and a jigsaw. I am guessing I will need some sanding equipment, but not sure what kind would be best.
Is there anything else that I "must" have to complete this project? Any hints as to the exterior appearance? I like minimal designs, plus I have "minimal" experience, so easier is probably better.
The other furniture in the room is a mix of leather and oak. While leather coverd sections would be uber cool, somehow I don't think that is the right material for a beginner
