How to plug a 7/8" hole
  • davidtu
    • 708
    • Seattle, WA
    I am going to be putting a small fence in a garden. I am mounting it to railroad ties via two 4" lag screws. I have to countersink them and in order to fit the socket, the hole is rather large (7/8"). These will end up being below ground and I was originally planning to fill holes with an appropriate silicone sealer (I have something, I forget what--if you want to suggest what, go ahead).
    Now I am thinking of using wood plugs instead, but the plug cutters I find are all too small (e.g. http://www.hartvilletool.com/product/11298)
    So, what is the best way to fill the holes?
    Btw, Its a little late to suggest an alternative to such large holes, as I already have 'em. (But if there was a better way to go, let me know too.)
    Thanks!
    (and if you've been "following" this project, yes I know it is taking forever!)
    7/8" dowels?
    • Anna
      • 728
      • CA, USA.
      Maybe cut pieces off dowels?
        A 7/8" dowel as JR suggests is the obvious solution, but I don't think that's a stock diameter ... I think (emphasis on THINK) the sizes jump from 3/4" to 1".
        So you might need to either drill out the holes to 1", or somehow turn a 1" dowel down to 7/8".
          • 22084
          That's what I'd do -
          enlarge the holes to 1" and hammer in a 1" dowel, then use a flush trim saw to cut off even.
          • Wood_workur
            • 1914
            • Ohio
            • Ryobi bt3100-1
            Actually, dowels are often under size, so you have 4 options:
            1. affix the dowel with epoxy if it is loose in the hole.
            2. turn 7/8" dowels (if you have a lathe)
            3. find a holesaw with an id or 7/8", and drill out the center hole to 3/8", and use regular plus in the middle
            4. use a fly cutter
            I vote for number 1 or 4
            Alex
              • 22084
              4. use a fly cutter
              I find the store-bought dowels to be oversize and undersize. By up to +/-.010"
              Not to mention oval as well.
              if you want a snug fit, buy a spade bit 1" dia.
              Use a file or grinder and take off .005" on each side near the tip, tapering to 0" off about 1/4" up from the tip.
              Now when you drill you'll have a tapered hole to jam the dowel into.
              (Or do as I do, just bring some calipers to the HW store and buy some dowels you measure to be slightly oversize.)
              • Tom Miller
                • 2507
                • Twin Cities, MN
                Do the holes need to be filled?
                If it's to protect the bolt, you could use stainless.
                Just thinkin' outside the bun -- all the good answers were taken.
                Regards,
                • jnesmith
                  • 892
                  • Tallahassee, FL, USA.
                  Regards,
                  That's what I was thinking. If the holes are going to be "below ground", why the need for plugs?
                  John
                  • gerti
                    • 2233
                    • Minnetonka, MN, USA.
                    • BT3100 "Frankensaw"
                    My thoughts too. If it is to protect the screw, I'd use some 2-component filler or so. Seems to me a plain wood plug would be the 'weakest link' and rot away much before any of the other components.
                    • WayneJ
                      • 785
                      How about auto body filler "Bondo"
                      Wayne J
                      • messmaker
                        • 1495
                        • RICHMOND, KY, USA.
                        • Ridgid 2424
                        Bondo would work but so would some silicone caulk. You could turn a 1" dowel to fit on a router table with a straigt bit if you got to have wood and don't have a lathe.
