working with cedar - ugh!!
  • rickd
    • 422
    i've been working for a few days now on a garden bench made from cedar. i haven't worked with cedar for a few years - i guess the last time was prior to when i had my workshop. i'm thinking now that cedar is an 'outside' job - even if i do have a workshop.
    even with my grizzly 2hp dust collector going full blast i still seem to get fine cedar dust everywhere! i've got both a 4" duct off of my sharkguard and another 4" duct off the back of the bt3100 - but i'm ripping and cross-cutting 3" boards, so the shark-guard lifts up and cedar dust shoots out everywhere. this hasn't happened with any other kind of wood i've used.
    so, it's cut, sweep, vacuum, cut sweep, vacuum - cough, cough, cough! i hate this stuff - but, it should look good when it's done and finished - i hope anyway!!
    for my next cedar project, if ever, - it's going to be outside my shop!
    rick doyle
    Rick's Woodworking Website
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    Are you sure one of your hoses isn't clogged?
    I'm using alot of cedar right now and no problems as long as I turn the DC on.
    Lakota's Dad
    • MilDoc
      Can't say I had the same problems working with East Tx red cedar. Shop smelled nice and the dust wasn't bad. Maybe you have some from the wrong state???
        • 22108
        Low quality Western red cedar I use (sold as dog-eared picket fence boards) isn't particularly any worse dust-wise than any other wood.
        Smells nice.
        • JTimmons
          • 690
          • Denver, CO.
          We get Eastern red here, my only suggestion is wear some sort of mask when working with it. I didn't have a problem at first, but developed an alergy after working with it recently.
          I have noticed the same fine dust that you're talking about too.
          -- Johnny Carson
          • Ken Weaver
            • 2417
            • Clemson, SC, USA
            • Rigid TS3650
            When I did my parson's bench in cedar I could smell it in the shop but no more or less dust than anything else. If you're using a ZCTP with the BT, I put some 3/8" holes in the front area and it helped the shark get the dust, I use a shop-vac setup.
            Ken Weaver
            Clemson, SC
            • jziegler
              • 1149
              • Salem, NJ, USA.
              Rick,
              I had a lot of fine dust when I was working with cedar as well, although I was mostly using eastern white cedar. Of course, I am still using a shop vac and no shark guard, but I got dust everywhere in my basement. Just one reason that I want to get out of the basement soon... But the basement did smell great for a while.
                I too have always considered cedar to be messy stuff, but it may be a matter of perception. All the cedar I've ever worked with has been extremely light in weight, so I think the sawdust tends to be fluffier and spreads out farther and thinner than that of other, denser woods.
                I do like the smell, although I tend to sneeze more when working with cedar.
                • rickd
                  • 422
                  hi,
                  thanks to your comments and feedback i think i have the problem fixed - i take it all back, 'i love cedar' and it does smell great in the morning!
                  as suggested, i decided to check for clogs in my ductwork - again. i didn't find any jam-ups but i did find something else i hadn't noticed before - a pretty good 'bend' in the 4" flex hose that drops from the ceiling down to the sharkguard port on my bt3100. i installed this clear flexhose several months ago and recently i noticed that it had stretched quite a bit - i have been meaning to shorten it but never got around to it.
                  it wasn't really a problem as i have been working mostly with 3/4" stock. however with the cedar i have been using a lot of laminated boards 3" thick. this was just enough that when the sharkguard raised with the blade, it subsequently caused the flex-hose to bend at a pretty severe angle - i must have been looking down at the setup and the blade all the time and never even noticed it.
                  anyway, i shortened the flex-hose to the proper length(took about 6-8 inches off of it) turned on my dc, cut a few cedar boards - and voila!! no dust! amazing!! and very stupid of me! it reminded me of what phil mickelson said at 'winged foot' - "how could i be so stupid"? the big consolation was i wasn't on network tv .
                  so, thanks again for pointing me in the right direction. the more woodworking i do, the more humbling experiences i seem to find!
                  rick doyle
