I hate finishing!
  • wassaw998
    • 689
    • Atlanta, GA, USA.
    Well, I try to be safe so I appreciate the info.
    Another thing I'd add regarding blotchy staining; is I have had pretty good luck using dyes on some troublesome woods that normally would be a blotchy issue. All I've used to date are water soluable dyes, so I've not tried the NGR ones. I have used a dye, and then followed that up with a stain, and been real pleased with the results. I also have used a wash coat up front before staining to help with some of the blotchy problems. In fact, I am thinking on my red oak table, once I re-sand it back to bare wood (for the upteenth time), I may start back with dye, then a wash coat, then the stain, .... The dye helps to put the entire surface on a level playing field, in that it gets the color constant. I've never used a dye on oak however. They always recommend to try things out on a test sample.
    Chris
    • vaking
      • 1428
      • Montclair, NJ, USA.
      • Ryobi BT3100-1
      When I deal with oak - I always use stain sealer. It is the same solvent used in stain but without a color. It saturates the wood initially without affecting the wood color, after that the stain itself comes only in small quantities and provides even color.
      Alex V
