help with gluing a "too large gap"
  • gimpy
    • Nov 2004
    • 197
    • Flagstaff, AZ.
    I have cut out a 7 inch square hole, thru and thru, in a 3/4 inch piece of mdf. I have a 7 inch square column that I wish to sit in this cut out and then glue it in. I wanted it to be snug and tight. But, I made the cut-out a hair too big. The cut-out has about a 3/32 inch gap on one side which makes the column loose in it. Therefore, I am afraid that it is too big of a gap to get a good glue set. Any recommendations as to how to maybe tighten/snug this gap up a little so it will get a better hold and also maybe look a little better,also?
    I want this to be a permanent glue up. I do not want the column to be removable.
    thx, Frank
    Frank, "Still the one"
  • bebop
    • 13
    • Chantilly, VA
    • bt3100 of course :)
    gorilla glue
      Shim it with a slice of MDF
      • just4funsies
        • 843
        • Florida.
        Second the motion for gorilla glue. It will expand as it cures. Try to make the gap even side to side, so the largest gap isn't too big. Follow the directions for the glue (it is water-activated). Shimming will also work, but probably won't look great without an opaque finish. Frankly, the glue won't look great, either, but may be the lesser of the evils.
          second this one!
          I think this is the better way to go. If the gap is an even 3/32", then it will
          be pretty easy to do. Don't rip the sliver off completely because it will probably
          get sucked down. Rather let part of it dangle, turn off the saw, then crosscut
          the sliver off.
          The gorilla glue will expand but won't provide much of any hold.
          • scmhogg
            • 1839
            • Simi Valley, CA, USA.
            Frank,
            I disagree with the use of Gorilla Glue. While it does expand, the expanded glue has little strength. With the leverage of a column it would be easy to develop a wiggle or a wobble.
            Epoxy is one of the few adhesives that dries hard and fills gaps with strength. Any glue will work if you use shims as pappy said.
            I try to turn my screw-ups into a design enhancement. Cover the gap and glue and shims with small 1/4 round or small cove moulding. Fill the gap with a dark wood or dark epoxy to make an enhanced shadow line.
            Can you tell I make a lot of mistakes??
            Steve
              • 22106
              the sliver off.
              Yup! Yup! Yup! (won't take just yup for an answer so i say it thrice.)
              • gimpy
                • Nov 2004
                • 197
                • Flagstaff, AZ.
                I just threw out some old gorilla glue day before yesterday (it had started swelling the bottle). So, I did buy a small bottle of it today. I will also check to see if I can put a shim in it.
                Steve, I don't understand when you said, "Cover the gap and glue and shims with small 1/4 round or small cove moulding. Fill the gap with a dark wood or dark epoxy to make an enhanced shadow line". Could you further explain it for me, please? Sorry, I am so dense--long day, been up since about 4:30.
                thx for the suggestions. Frank
                • scorrpio
                  • 1566
                  • Wayne, NJ, USA.
                  Steve probably gave two completely different suggestions in one sentence there. Should be 'either use moulding to cover it all up or fill with dark epoxy to create a shadowline.
                  I suggest shimming it. Do not count on gorilla glue expansion - in my experience, the foam formed by the glue is very brittle, and it is usually the squeezeout that foams up - probably for easier cleanup. If you get 'expansion' between the parts, you can be sure the joint will fail. Epoxy is the glue to use if you want it to fill a gap.
                  • tmaceroli
                    • 133
                    • Forked River, New Jersey, USA.
                    A recent issue of Wood magazine had an article on gap-filling glues. It was in the past couple of months, so the issue is probably still readily available on the shelves of your local library.
                    Unless you find a glue specifically for that purpose, then none of the usual wood glues, Gorilla Glue included, are going to provide any kind of joint strength. Wood glues require wood-to-wood contact to bond correctly.
                    Tony
                    "Nothing would be done at all if a man waited until he could do it so well that no one could find fault with it."
                    - Cardinal Newman
                    • gimpy
                      • Nov 2004
                      • 197
                      • Flagstaff, AZ.
                      Well, I did both. Shimmed it, then glued it using gorilla glue. Doesn't look too bad. Will have to wait until I can throw some paint on it, then will see what it looks like.
                      thx, Frank
