Which adhesive?
  • Salty
    • 690
    • Akron, Ohio
    Which adhesive?
    What could I use to glue sandpaper to a piece of PTFE plastic?
    I made a rail coping sled using a piece of this plastic 1/4" thick. It works real good at sliding on the router table but it could use some help at holding the stock. I still need to get a push down clamp and the addition of the sandpaper would be great.
    Any ideas?
    Would something with PSA work?
    Thanks.
    Salty
    PTFE is teflon. Going to be hard to get something to stick to that reliably.
    http://en.wikipedia.org/wiki/PTFE
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      scuff the surface well and try PSA or a spray glue like 3M super 77.
      • Salty
        • 690
        • Akron, Ohio
        Wait a minute. In my effort to seem smarter than I really am, I may have used the wrong term for the plastic. When I saw that LGHIEN refered to PTFE as teflon, I realized that I may be wrong there so I will check on that today. It is refered to as a polymer and came from here.
        http://www.dxengineering.com/Parts.a...DXE%2DMMP%2DP3
        Sorry all...I'll get back to you on that!
        Salty
        • scorrpio
          • 1566
          • Wayne, NJ, USA.
          "Material: black polymer plastic" Wow, talk about being descriptive. It's like lumber yard selling wood, and putting 'wooden wood' tags over all their products.
          It could be PTFE, could be HDPE, could be UHMW-PE. (btw, I am still not sure if HDPE and UHMW-PE are not the same thing).
          Either way, these are all self-lubricating. You'll need something that can dissolve this kind of plastic in order to glue anything to it.
          • sacherjj
            • 813
            • Indianapolis, IN, USA.
            I would second the 3M 77 Spray idea. I've bonded with various plastics pretty well. Scuff the surface with a moderate sandpaper (120-200) and follow the directions on the bottle. Great stuff.
            Joe Sacher
              I did not find this to be ideal but I used left over skid resistant tape for my boat trailer on one coping sled. It has a pretty strong adhesive on the back to stick to steel surfaces (does not need to penetrate to hold). What was not ideal was the fact that it had a little bit of give to it. It helped hold things in place pretty well.
              What about self adhesive sandpaper? It comes in rolls or individual pieces for sanders that do not have hook and loop plates on them.
