Table top fasteners
  • sthompson82
    • Jan 2005
    • 45
    • woodstock, ga.
    Table top fasteners
    Does the BORG or Lowes sell the figure 8 table top fasteners? Or do I need to make the long trip to Rockler or Woodcraft? What about hardware stores?
    Thanks
    I do what I do
    • 22109
    not that I know of.
    There's a radical new idea called the internet - you can buy stuff and they'll mail it to you for a lot less than the time and gas to go to a brick and mortar store. If you feel bad about spending 5 bucks S&H then treat yourself to a fe more items to make the S&H worthwhile.
    • Tom Miller
      • 2507
      • Twin Cities, MN
      quote:Originally posted by LCHIEN
      ....There's a radical new idea called the internet....
      Then there's the tried and true idea of being cheap. I would die before paying $5 shipping for a $3 part! [:0]
      Yet, somehow, I'd use $6 of gas to save the $5 shipping, so go figure. [:I]
      Regards,
      • sthompson82
        • Jan 2005
        • 45
        • woodstock, ga.
        In-ter-net???? Is that the inner lining they are putting in swim trunks?
        Yeah, I found them online, but that $6 in shipping is what had me looking elsewhere. I probably made it sound like I would be driving real far to get to a Woodcraft or Rockler, but in reality it is only about 20 minutes away. Thanks for the info
        I do what I do
        • kwgeorge
          • 1419
          • Alvin, TX, USA.
          I would pay $5 or more in gas and time to buy what I want local. If you can call either Rockler or Woodcraft local for me.
          I guess I have a patience problem and when I want something I want it then. I hate waiting on stuff to come UPS or whatever.
          I have bought the figure 8’s at Rockler.
            A general shopping tip that may prove useful to some: any time you're ordering stuff online, check to see where the shipping rate "sweet spots" are; i.e., $5.95 for orders up to $25, $7.95 up to $50, $9.95 up to $75, etc. When your subtotal is getting close to one of these points, fill out your order with inexpensive items (such as the figure eights being discussed here) you might not necessarily need TODAY but you know you will surely need SOMEDAY.
            This approach accomplishes three things. First, it effectively makes the shipping free for the small stuff. Second, it's a good way to build up your personal inventory so you'll be more likely to have what you need, when you need it, instead of having to make a special trip or order. Third, it spreads out the cost of this little but vital stuff so that you barely even notice you had to pay for it.
            • mschrank
              • Oct 2004
              • 1130
              • Hood River, OR, USA.
              Another thing, IF Home Depot or Lowe's sold them, they would likely be ridiculously expensive. I needed some T-nuts (not Jeff's type for the BT3K, just regular T-nuts), and didn't have time to wait to have them shipped. BORG charged something like $2.00 a piece...had them individually packaged in the "specialty hardware" section.
              Even Rockler will sell you 8 for less than $2.00!
                Thanks
                If you want to avoid the S&H charges, you can make your own table
                top fasteners out of wood and screws. They are called wood buttons
                and have been around longer than figure 8s. I'm assuming your table
                has aprons. You cut a 1/4" slot in the apron maybe 1/4" from the
                bottom of the top. The buttons are 1" wooden blocks with a 1/4"
                tongue that extends into the slot you cut into the apron. You screw
                through the button into the top to fasten. Some people use a
                biscuit jointer to cut the slots in the apron and size their buttons
                accordingly.
                Paul
                  • 22109
                  Thanks
                  accordingly.
                  Paul
                  I was thinking of suggesting that very thing when i made my reply. That'll surely work.
                  • JohnnyTest
                    • 172
                    • Joppa, Maryland.
                    With the price of gas and tax on the item, S&H is well worth it to me.
                    • Whit
                      • Apr 2003
                      • 110
                      • Denton, Tx, USA.
                      • BT3000, BT3100
                      I am really cheap. I have used large fender washers screwed to the table top. For slots in the apron, I used a biscuit joiner. Works for me.
                      Whit
                        Whit
                        Whit, that's a good one. You should consider sending that into a magazine. I'm
                        going to have to try this out next time I do a table.
                        Paul
                        • billwmeyer
                          • 1868
                          • Weir, Ks, USA.
                          If I had a Rockler's or Woodcraft within 20 minutes I would use it as an excuse to go there!
                          Whit, I think that is a great idea also depending on what you're making.
                          • onedash
                            • Mar 2005
                            • 1013
                            • Craftsman 22124
                            I just pocket hole screwed my top to the frame/apron. Hope it doesn't fall apart someday.
                            • Crockett
                              • 253
                              • Buffalo, NY, USA.
                              package of 8 table/desk top fastners in the store (Rocklers) 4 bucks.
                              http://www.rockler.com/search_result...e+top+fastners
                              Al
                              Al
