Parting BT3000
  • smackd78
    Handtools only
    • Jul 2011
    • 3
    Parting BT3000
    i am parting out my BT3000. I recently got a nwer saw and don't have room for both saw. Below is what i have available.
    the sliding miter table was drop a few weeks ago and actaully broke the top of the table. The lifting mechinisim is also stripped out as well. I am keeping the stand as i will be using it on my new saw. I am central florida. make a resonable offer on price, would prefer local.
    standard rails (silver)
    broken (miter sled)
    aceessory table
    blade guard
    standard motor (not sure of amps, not labeled)
    zero clearance insert (1 cut, 1 uncut)
    dado insert
    rip fence
    • 22086
    whats numbers on the label plate on the back of the saw?
    Amp listed there will be the motor amps.
    The serial number will reveal the build date, too.
    • smackd78
      Handtools only
      • Jul 2011
      • 3
      Ok ,it was on the side panel (i had it removed so that i can move the saw up and down since) below is what is stated on the label
      RYOBI 10" TABLE SAW
      BT-3000 Ser No 795184 9416
      120 V.AC * 15A * 60 HZ * 4800 R.P.M.
        • 22086
        RYOBI 10" TABLE SAW
        9416 = 1994, week 16 (approx late March), build date.
        • All Thumbs
          • Oct 2009
          • 322
          • Penn Hills, PA
          • BT3K/Saw-Stop
          If it has the solid aluminum (or whatever, just not plastic) handwheel, I'll take that.
          • smackd78
            Handtools only
            • Jul 2011
            • 3
            Someone beat you to the handwheel, but if it falls through i will get back with you.
