Well, the time has come to part this guy out. The prices listed are just for the item itself. Shipping will vary depending on distance & total weight. Lots of stuff here. Email or PM me with wants/questions. Prefer paypal, but checks also work.
First, the addons:
Original SharkGuard splitter & hold down (slot-tab design) - no actual Shark - $20:
http://wilsonmanorcrafts.com/saw/IMG_4483.JPG
Later version SharkGuard splitter & hold down (2-pin design), both thick & thin splitters - no actual Shark - $30:
http://wilsonmanorcrafts.com/saw/IMG_4482.JPG
Fence mounting blocks - set of 4, milled aluminum, with screws - $20.
http://wilsonmanorcrafts.com/saw/IMG_4485.JPG
PAIR of Lee's zero-clearance throat plates, UNUSED, with one already pre-cut - $45 SOLD
http://wilsonmanorcrafts.com/saw/IMG_4491.JPG
http://wilsonmanorcrafts.com/saw/IMG_4495.JPG
One UNUSED Ryobi dado/zero clearance plate, and one REALLY used plate, With instructions - $15:
http://wilsonmanorcrafts.com/saw/IMG_4492.JPG
http://wilsonmanorcrafts.com/saw/IMG_4493.JPG
Original metal plate and dado plate. Original plate is slightly used, dado is not. With instructions - $15.
http://wilsonmanorcrafts.com/saw/IMG_4494.JPG
Sears/Ryobi micro positioner for the fence, used - $10: SOLD
http://wilsonmanorcrafts.com/saw/IMG_4486.JPG
Bunch of T-Nuts for the fence and etc, with nice storage case: $25 - SOLD
http://wilsonmanorcrafts.com/saw/IMG_4489.JPG
Miter addon table - $25: SOLD
http://wilsonmanorcrafts.com/saw/IMG_4502.JPG
Half-rails, 23.5" long, front and back - $30: - SOLD
http://wilsonmanorcrafts.com/saw/IMG_4501.JPG
Full rails, 41" long, front and back - $45:
http://wilsonmanorcrafts.com/saw/IMG_4500.JPG
Mounting/connecting plates for adding rails. Heavy steel, bolts, and tnuts included. $25:- SOLD
http://wilsonmanorcrafts.com/saw/IMG_4487.JPG
Miter fence hold down - $5: SOLD
http://wilsonmanorcrafts.com/saw/IMG_4488.JPG
Miter fence, has nick on right hand plastic from not avoiding the Red Line - $15:
http://wilsonmanorcrafts.com/saw/IMG_4496.JPG
Sliding table, in good working shape, but a little dingy - $35:
http://wilsonmanorcrafts.com/saw/IMG_4503.JPG
The fence, in good shape, newer than the rest - $35: - being held
http://wilsonmanorcrafts.com/saw/IMG_4497.JPG
Extra "fence tube" - can be used as an extra long miter fence - $15:
http://wilsonmanorcrafts.com/saw/IMG_4498.JPG
Wrenches - $5:
http://wilsonmanorcrafts.com/saw/IMG_4490.JPG
And finally, the saw itself! Since my saw was built into a rolling base, I had removed the left panel and put in a custom access design from MDF. The panel has long since been lost/given away. The back of the saw was also closed up with a box to handle dust collection, with the MDF glued right onto the saw body. So yes, that's icky.
However, the rest of the saw is intact. The dust shroud, motor, belt, lifting mech, handle, etc, etc.
So for the saw itself, if you want a SPECIFIC part or the WHOLE THING AS-IS , you need to let me know ASAP and Make An Offer before someone else buys a bit before you do.
http://wilsonmanorcrafts.com/saw/IMG_4504.JPG
http://wilsonmanorcrafts.com/saw/IMG_4505.JPG
http://wilsonmanorcrafts.com/saw/IMG_4506.JPG
http://wilsonmanorcrafts.com/saw/IMG_4507.JPG
http://wilsonmanorcrafts.com/saw/IMG_4508.JPG
First, the addons:
Wrenches - $5:
