8' Power Twist V-Link Belt
  • kshoemaker
    • 69
    • Grayslake, IL.
    I bought 8’ from Rockler a while back and used it to prototype a screw driven TV lift. I ended up changing my design, and I don't have any tools that use V belts. They’ve been used for maybe 10 minutes and I gotta start paying for all the bargains I find here.
    Looks like 4' lengths go for $24ish. I'd take $40 for all 8' w/free shipping. Or feel free to make an offer.
    Thanks.
    BTW, when I first joined this site I posted links to my ebay auctions. I apologize for that breach of etiquette. I don't have much good stuff but it'll go here first.
    Shoey
  • sacherjj
    • 813
    • Indianapolis, IN, USA.
    Do these vary in size? I'm thinking about putting V-Belts on my drill press and jointer. How do I tell if these are the correct size?
    Joe Sacher
    • kshoemaker
      • 69
      • Grayslake, IL.
      They are adjustable in 1/2" increments, which made them perfect for trying different pulley positions in my case. The links connect to each other with a Double Piggyback Twist Lock mechanism (I made that up). These pics will give you a better idea.
      I'll sell in shorter lengths too. Just make an offer. Thanks.
      Shoey
      • sacherjj
        • 813
        I understand about how the belts work as far as length, I just didn't know if there was a standard size for width. If these will fit my jointer and drill press, I'm interested in the full 8'.
        Joe Sacher
        • DaveW
          • 415
          • So Cal.
          See http://www.bt3central.com/showthread.php?t=15316
          • kshoemaker
            • 69
            • Grayslake, IL.
            This size fits 1/2" pulleys. The links are about 1/2" wide on the outside edge and about 0.4" to the bottom of the V. If it doesn't fit I'll gladly take it back.
            Shoey
              • 22028
              when i was researching this a while ago most WW equipment for home shop use took 1/2" V-belts and the 1/2" link belts were the recommended replacement.
              The major exception is the BT3000/3100 of course which uses a custom belt.
              • krell-one
                I sent you a PM
                • sacherjj
                  • 813
                  Good. It looks like it will work. I'm interested in the full 8' if you haven't sold it already. $40 is fine.
                  Joe Sacher
                  • kshoemaker
                    • 69
                    • Grayslake, IL.
                    I PMed you.
                    Shoey
