Carpenter bees
    Just me
    • 8445
    Originally posted by capncarl
    There is something about the angle the hood has to be drilled in the trap that makes them work, otherwise the bee can crawl back out.
    In the detailed explanation in the article, it said that at the top of the angle, there was less light coming in from the smaller entrance shaft than coming up straight from the bottom in the larger hole; upon getting ready to exit, they take the larger hole with the most light and end up in the jar.
      Internet Fact Checker
      • 21032
      forty five degrees angled up.
      • os1kne
        • 901
        • Atlanta, GA
        I've had my trap up for a couple of years or so. I recommend that if you're doing this, place the trap early in the year. I trapped a bunch of carpenter bees in April / May, and only a couple since then. Good luck.
          • 21032
          Carpenter bee trap update - improvement advice
          I originally made the trap with a small glass jar, specifically Wylers boullion cube jars with plastic lids.
          I kept finding water in the jar, a lot of it. I sealed the lid to the wood all around before screwing, assuming driven rain, but it still fills with water.
          Eventually I figured it out - the glass gets cold overnight. In the AM, the moisture condenses on the inside and outside of the cold glass as the air warms up and leave a few drops every day. Not a lot but a week of cool, humid mornings and you end up with half an inch of water.
          I eventually replaced the glass jar design with a smaller but still bee catching sized plastic pill bottle with a snap or screw top. The plastic warms up quickly and doesn't condense water like the glass does.
          I usually let the bees accumulate (I've read the scent of the old bees attracts new ones) but the standing water turns the bees to mush and has to be emptied periodically bees or not.
            • 21032
            This spring I caught four bees in the last couple of weeks. They were quite busy around the fences and I had 2 traps, put up a third near where they were hanging out. They were getting very aggressive around my wife who fears them greatly - they do look menacing and buzz your head, but they don't sting or bite. After a couple of days they were all gone, caught in the traps. They work quite well. I've seen one other bee hanging around for a day or two, then he's gone. Not in the trap but not here anymore, either.
            Made a couple more tonight in the shop using the 45° drilling jig I made and some short scrap pieces of reclaimed PT 4x4. Easy to make once you have a jig. The holes are pretty deep, you need a DP with a good 3.5" stroke or you may have to finish with a hand drill. Oh, yeah, I used a Forstner extension shaft, although I'm pretty sure I could have used a spade bit I have with a longer shank.
            In the past I gave one trap to the neighbor on the right, I'll give one to the neighbor on the left.
              • 21032
              Maintenance: every once in a while you have to use some compressed air (or a wood pencil) to blow out the holes... for some reason the spiders like to build cobwebs in them then they catch bits of grass and get plugged up. I had a couple of small geckos crawl up inside, I guess they thought it was a good house, but they apparently had no trouble getting out.
