All,
We are renovating 2 rooms in our home including painting, new trim, and new carpet. The question I have is what order should the carpet / trim be replaced ?
Since we are painting the walls and ceiling, my first though is to get the old carpet out. Then once everything is all painted get the new carpet in and then the trim. Some have told me, however, that the trim should be in first since the carpet must be tucked under it to look right. Additionally, I have been told that trim is hard to get level across the room if carpet is already in. If I put the trim after the painting but with the carpet removed, I assume I must somehow shim it up to leave room for the carpet. Wouldn't it get banged up when the carpet gets installed then ?
I would appreciate any feedback on the proper order to do the trim / carpet so that things look right.
Regards,
Pete
Buckeye95
Regards,
Pete
Buckeye95
