Shoring up a stair railing...
  • cooterbrown
    • Mar 2013
    • 30
    Hey,
    Last night I was walking upstairs to my kids rooms and noticed how lose and wobbly the stair rail had become.
    The house is 15 years old - so it's pretty conventional stuff here. nothing exotic.
    Most of the posts are very loose and wobble and clatter in their railing holes.
    I have never dealt with this sort of thing.
    Looking for advice on HOW to firm everything back up again/get everything tight/stabilize the railing again.
    Any help is appreciated! Thanks!
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    To make repairs without pulling them completely apart:
    One option is to drill and inject glue into the joints. Another option is to mechanically fasten them with screws. Or you could do both.
      I was going to make a snarky remark about calling Tom Silva. Then I thought, "Hey, ToH probably has an answer to this problem."
      Sure enough:
      http://www.thisoldhouse.com/toh/askt...248114,00.html
      • Carpenter96
        • Aug 2011
        • 178
        • Barrie ON Canada
        • BT 3000
        If this is a wood rail and balusters then Tom Silva's fix is the way to go.
        Regards Bob
          Without a picture or more detailed description it's hard to know exactly what you want to fix. If it is just the ballisters rattling in their holes, the wedge or finish nail trick at the link will help. If the handrail itself moves and is not confidence inspiring, you have to look at the ends where it attaches. Carpenters do not do anything magical to attach a handrail. I've had them use staples in a oak handrail on a pretty expensive house. A plugged screw is better than staples. A hanger bolt (screws on one side, threaded bolt on the other) is significantly better. Essentially you have to determine what you have and then decide on how you're going to fix it.
            • 3745
            I fixed a wobbly handrail on a set that would be waaaaay to much to take down and repair by using a Kreg pocket hole jig. Clamped the jig to the post a little farther from the edge than normal to give more wood in the post and screwed it together with several long Kreg type screws. It was finished by inserting a wooden peg dodad that is made for pocket hole screws, and restained. This even worked well for loose ballisters.
            capncarl
            • JSUPreston
              • 1189
              • Montgomery, AL.
              I know this is absolutely no help, but I got the mental image of Clark Griswold in the Christmas Vacation movie taking his chainsaw to the newel post.
