Stair advice needed
  • jdon
    • Feb 2010
    • 401
    • Snoqualmie, Wash.
    Re: tread width- Could you attach an oak strip, say 2" wide, at both ends of each tread, to give a breadboard appearance? That way you could meet code, give a finished, even customized, look, and not have to deal with poor quality and expensive replacements.
    I'd think that with risers supporting the full width, the joint wouldn't have to be extraordinarily strong- pocket screws, biscuits, or even just glued could work. Being narrower and thicker than a panel, say, cross grain movement shouldn't be as great a concern.
    I sympathize with the size constraints of the room- any solution is a compromise. Good luck!
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      You need to find out what your local building code dictates. With my limited knowledge of stair building and code your original landing and stairs appear to be close to meeting code, your proposed stairs do not meet code. Landings must be at least 36" in the direction of travel. So if your original landing was 36" x 36" it meets code.
      http://www.co.stevens.wa.us/landserv...WAYSECTION.pdf
      http://inspectapedia.com/Stairs/Stair_Codes.htm
      • JeffG78
        • 389
        • Sun City West, Arizona
        Landings only need to be there if the door swings out towards the stairs. Every basement staircase falls into this category which is why basement doors always swing away from the staircase.
        This would fall into an interior door category per the link you provided so the exterior landing would not apply. Thanks for the link though. I had not seen any codes that mentioned exterior doorways.
        • mpc
          • 1018
          • Cypress, CA, USA.
          • BT3000 orig 13amp model
          Are there any doors to the outside from this room? If so, I'd put the stairs on that side so both share the same wasted space. A landing with stairs along the house wall, rather than straight out the sliding door as you sketched, I think would look better. I'd make them even larger - and then make the area underneath the landing usable storage space. Stick a mini-fridge in there, a few shelves and/or a cupboard to store a few glasses, plates, maybe a dinky microwave, whatever... so this room becomes an eating nook. A couple electrical outlets for the coffee pot and a TV or radio perhaps?
          If getting plumbing to the area is possible, imagine this:
          make the landing with stairs going off one side (similar to what was there), I'd even make the steps turn 90 degrees in the corner of the room... the other side of the landing would then continue to the other wall and have a small sink/wet bar. Hang a flat-screen TV in the corner above the bar (basically between the wall of the patio room and the sliding patio door.)
          As for that exposed truss: cover it but include a shelf near the bottom edge to display nick-knacks. That way as folks come from the main house to this room they're eyeballing decorations that means something to them, not an odd wall space.
          mpc
          • mpc
            • 1018
            • Cypress, CA, USA.
            ...or create a new floor for the whole patio room that is just one step down from the main house... if headroom allows...
            mpc
              • 22055
              it might be useful to see a dimensioned plan view of the sun room... We really have no idea how narrow it is or how much room there is to the right of the door... and thus can't visualize the proportions.
                Is there enough room for a landing in front of the opening door, width of door + railing, then turn left to descend toward corner, 90 degree to right in the corner (with or without second landing) to end stairs by the window on that left wall?
                • Zip1
                  • 19
                  • Milwaukee, WI, USA.
                  #23
                  I would not want to have to walk forward from the house towards the "truss" you show on post #4. I'd instinctively want to duck below the truss as I descended the stairs.
                  Looks like you replaced the window (to the left as you exit the house) with a sliding door.
                  I'm back to capncarl's suggestion to reverse the direction of the stairs from original. I would have a square (30-32") landing just outside the door enclosed by railing and have the stairs begin next to the fixed glass panel of the door. This way, looking out the full width of the sliding door, you'd see level railing on the right half and descending railing on the left half, still giving a sense of security from falling. This would also have the advantage of a more direct traffic pattern from the new sliding door to outside.
                  If you made the square landing 30-32" and included railing within that dimension, and then boxed in your stringers (pix 5 post 1) you could likely re-use your original treads, since their width would be inside the boxed stringer.
                  Edit: Oops, is that new sliding door just propped up against the original window? Either way, I think this option saves the most space and would be the most attractive, both from inside and within the sun room.
                  • Carpenter96
                    • Aug 2011
                    • 178
                    • Barrie ON Canada
                    • BT 3000
                    #24
                    I agree with Tom Slick, find out about your local codes. Here in Ontario you have to divulge any non-conforming items in the house. If you go to the trouble of building stairs that do not meet code it may decrease your selling price. Is there an exit to the out side from the sunroom? If there is you have to put in stairs that are wider than you would like. I regularly teach stair building to carpenters and apprentices and the most important thing is to at least meet code. We teach good building practice, which far exceeds code. Are winder stairs allowed in your area? That could save some space. Some more to think about.
                    Regards Bob
                    • JSUPreston
                      • 1189
                      • Montgomery, AL.
                      #25
                      I think make the landing the depth it is now, but have the stairs on the opposite side of the original. Have the landing the width of the operating door, and have the first drop off where the fixed door is...assuming that it up to code.
                      Another observation...you have a beautiful 4 legged family member.
                        You can get 36 inch treads from "stair parts now" (google it) for $30 (oak). They also have longer ones and other species. I haven't ordered from them, yet, but found them looking for balisters. I need a bunch because the spacing in our new (old) house are too far apart.
                        • tfischer
                          • 2349
                          Maybe the pics are deceiving, but the red "proposed" stairs jutting out into the room look like they'd be a lot more disruptive than the original landing.
                          I'd go with the original design, but modify it so the "landing" is a step lower than the door. That would eliminate one step off the width of it.
                          If you're only doing this to sell the house, you just need to make it look good, and let the new owners worry about the practicalities of adding furniture
