Painting over rusty metal roof
    Today I got two free gallon cans each of primer and paint from my neighbor to paint my metal porch roof.
    Paint:
    http://www.weatherbarrier.com/wb/wb....ic-Roof-Finish
    Primer:
    http://www.weatherbarrier.com/wb/wb....Primer--Sealer
    The instructions say to use their Rust Inhibiting Primer underneath the primer and paint:
    http://www.weatherbarrier.com/wb/wb....ibiting-Primer
    My roof just has some rust spots here and there and it's not really that bad. However, I can't buy their stuff locally and it's going to be $51 for a gallon after shipping.
    OK, I'm probably being overly frugal (cheap) but I don't need a whole gallon; I just need to spot treat a few areas.
    I'm sure if I ask them, they're only going to recommend their product. However, do you think I could use something like this Krylon rust converting primer?
    http://www.krylon.com/products/rust-...erting-primer/
    Thanks,
    Paul
    • 10481
    I used something similar to the Krylon from Rustoleum. I'll have to check the paint locker and see if there is any left to be sure which one it is. I did a small test spot on the roof of my '65 to see how it worked. Will try to post a picture of that this evening.
    When the day comes to get serious about the restoration of the Chevy I plan to use a product called Rust Bullet on the frame and as a primer.
    • frumper64
      • 376
      • Garland, Tx, USA.
      I have used a product called POR when I was working on an old Corvair - the stuff is fantastic with the only caveat being that you have to paint over it or the black color will bleach out in the sun. They sell a "starter kit" for $22 that includes a 4 oz can of the stuff plus some metal prep and degreaser. I don't know if that would be enough for what you need, but you might want to take a look.
      http://www.por15.com/SUPER-STARTER-KIT--Black_p_11.html
      64sedan_at_gmail.com
      • tfischer
        • 2349
        OK I just have to ask this... how bad is your roof that your neighbors are giving you free paint?
          Haha. Well, I can't see the sky yet, so not so bad, I guess. Man, I wish all neighbors would be so concerned for my house. Maybe I should spread the word that I need house paint, too.
          Our neighborhood has a listserv and someone posted they had extra roof paint and primer from their job. Just go pick it up from their porch so I did. I've actually never met the person, though. They live about 4 streets over.
          Painting the roof is on my to-do list. It's pretty flat and only one story up so should be doable in a couple of weekends. I'll leave the 2nd story windows unlocked in case I paint myself into a corner.
