Electrical Serge took out Water Heater
  • thiggy
    • 229
    • Alabama.
    • Craftsman Contractor
    If it were mine, I would turn off the breaker to the water heater, open both access panels and check the two heating elements with a continuity tester. That may show up an easy and inexpensive repair.
    SOW YOUR WILD OATS ON SATURDAY NIGHT - - - THEN ON SUNDAY PRAY FOR CROP FAILURE!
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      I would agree if it is just a simple water heater. If it has a circuit board though, I would not chance it.
      • Stytooner
        Roll Tide RIP Lee
        • 4301
        I am not real savvy when it comes to circuit boards and electronics.
        My typical procedure is replacement.
        The reason is I have tried before a few times to replace a defective part on a circuit board. One I recall was replaced easily enough. Then installed again and the very next part inline failed.
        No safeties involved, but in the end, much cheaper to either buy new, or in that case, get a new circuit board.
        • Ian57
          • Sep 2012
          • 42
          • Cocoa, Fl.
          • Delta 34-455 Contractors Saw
          It did thanks
          • Ian57
            • Sep 2012
            • 42
            • Cocoa, Fl.
            Thanks You
            Thanks I checked the elements neither were working. Should be able to replace myself.
            Thanks again for all the help. Really appreciate it
              Internet Fact Checker
              • 21054
              nine times out of ten the part that fails visually catastrophically on a circuit board is a symptom, not the cause. The exceptions are ruptured capacitors which you would have to know what they were.
