You can do that but just remember your new tile job is only as good as the adhesive, etc you skimmed over.
If you use Armstrong VCT or was it the Henry Adhesive, the warranty states 80% of the old adhesive must be removed.
On another note. Do not use bottom of the barrel cheap adhesive. I spec'd Henry 430 Clearpro adhesive rated for up to 90% RH in the concrete slab for our project at work. You get what you pay for in adhesives too. That gives you a 10yr warranty on the adhesive. A lot of them are only 5 year.
Armstrong and Mannington are the only 2 tiles brands I am aware of that are same color chipped through the whole tile.
