Water Pressure Low
  • BigguyZ
    • Jul 2006
    • 1818
    • Minneapolis, MN
    Water Pressure Low
    So my brother and I do a lot of work on houses, and there are two that I've re-plumbed just recently.
    Both were run with PEX lines as a home run system (each fixture has their own line, going into a manifold). The curious thing is that the system should have oodles of pressure. The heating system, which is part of an open system with the potable plumbing, shows the presure at 65PSI.
    However, it seems once I install the faucet the pressure drops significantly. Is that a function of how the internal mixing valves work these days? Is there any brand/ type that's better than the others? It seems to be an issue with the sink faucets too, so I'm not sure what's going on here.
    Thanks,
    Travis
  • DannyT
    • Sep 2012
    • 28
    • Groveport, OH
    is the pressure low in all of the faucets? when you open a faucet what does the gauge on the heating system read? all faucets do reduce the pressure somewhat. do you have better pressure with the aerator removed?
    • eccentrictinkerer
      • Aug 2007
      • 669
      • Minneapolis, MN
      • BT-3000, 21829
      Are you judging flow by volume, gallons per minute, or pressure?
      I used 1/2" PEX in home run circuit and found the volume was reduced a lot. Look at the inside diameter of the Pex tubing versus copper. It's significantly smaller than copper.
      I now use 3/4" for all circuits now. Costs a tiny bit more but it's worth it.
      BTW, all faucets except tub faucets are required to have flow restrictors now.
      Many of my customers ask me to modify them.
      • BigguyZ
        • Jul 2006
        • 1818
        • Minneapolis, MN
        I'm judging by pressure. The pressure at the stop seems to be pretty darn good, it's the pressure with the faucet in that seems to drop off dramatically.
        So I'm sure it's the faucet more than the piping- a lot of PEX manuals actually reccomend 3/8" for home run systems. If you had a multi-head shower, I could understand using 3/4" for that one item in a home run system. Otherwise, I really wouldn't see 3/4" being necessary at all for a home run system overall. Cost aside, it'd also be extremely difficult to run all of that in wall/ between joists.
        • Daryl
          • 831
          Try taking the aereators off the faucet and clean the screens. New plumbing often has a lot of fine debris that will collect and plug the screens, doesn't take much to cut the flow back a lot.
            • 22051
            good thought!
            when you say the pressure is low is that the static pressure or the running pressure?
              Could be just a defective faucet.
