Ok,
So, I have moved onto my next project in this old house renovation and have a big issue to take care of now. This apartment I am renovating is on a second story. The first story is where my grandmother lives currently.
The living room in the apt. has a 16 foot span between the exterior supporting wall and the interior wall. This is balloon framing - so not what we usually look at.
The big issue I have, is that the 16 foot span is carried by 2X6 joists. These are old, true 2X6 joists and many of them are actually closer to 6.5-6.75" tall. The floor bounces like a trampoline. This should be expected, since 2X12's would be preferred for a 16 foot span, and 2X10's appear to be the real minimum that most people desire.
My plan on this is to leave the joists that are there in place, tear up the sub floor above, and rebuild the floor system. Originally I was thinking of sistering joists, but since they're 2X6, I realize that will not be sufficient.
Once I have the floor off, I am thinking I should be able to take a 16 foot 2-by-whatever, slide it down onto the support wall, and then back to the second support wall, and nail and glue it to an existing joist or the opposite side of the stud that the current joist is on.
I would HAPPILY go to a 2X12 here, since the cost is probably only about $100 difference, but if I do that I will be raising the floor up about 4-5". This floor currently mates to the kitchen floor almost perfectly - so there would be a considerable and awkward step up. The door frames would also be reduced to about 72" tall from their current 78", and the plumbing pipes that come in for the heaters (retrofitted well after the house was built) would need to come up (which will be hard).
I REALLY need to keep the celing below in tact, or it would be easy to just drop the ceiling below by about 6" from it's current 8+ feet and I'd be happy...but I can't do that. I have to work from the top.
So, I thought of steel beams - but then I realized that 6 2X6 steel beams, 16 feet lont, will weigh about 1200 pounds, which will be quite the increase on the support members that the beams will be sitting on.
My next thought is that since the lumber in place is actually close to 6.5", maybe I can squeeze a 2X8 in there, at 12" OC intervals - which would still raise the floor, but not so much that it would be unbearable. My calculations using span calculators show that this may come close to the 15 foot span that I need, if I allow for extra deflection. I'm thinking that sistering the 2X8's and then blocking the joists in 3 seperate places will decrease the deflection....
So, my questions are:
1.has anyone come across a similar situation and how have you dealt with it???
2. What are your thoughts on the plans above?? I believe some of you may be structural engineers even...or not...who knows?
3. If I were to raise the floor, any ideas on how to deal with that? It's too short for a step, too tall for no step....
LCHIEN
