Airlocked Plumbing?
    Airlocked Plumbing?
    I replaced the tub faucet in my 2nd floor bathroom. When I turned the water back on, everything ran fine in the basement and 2nd floor but the main floor has very reduced water pressure. I'm thinking it has some how airlocked. Now how do I get rid of this?
  • thiggy
    • 229
    • Alabama.
    • Craftsman Contractor
    What fixture has poor pressure? (I assume you mean low flow rather than pressure.) If it is a sink with an areator, then you may just have a clogged screen. Remove the areator where affected and see if there is mineral deposits or rust hindering the water flow.
    SOW YOUR WILD OATS ON SATURDAY NIGHT - - - THEN ON SUNDAY PRAY FOR CROP FAILURE!
      • 22061
      you could shut off the water supply to the house, then open a faucet at the lowest point in the house to drain all the water out of the system to start over if there's some air pocket screwing things up.
      • Kristofor
        • 1331
        • Twin Cities, MN
        • Jet JTAS10 Cabinet Saw
        If you crack every faucet/fixture open slightly at the same time I'm not sure I could think of a scenario where you could maintain an airlock in the pipes without strange loops above/below the various outlets. Maybe I'm missing something obvious...
          Update: Bathroom taps and toilet are now running better. I took the screen from the kitchen taps and it has improved but still not great. I think that the problem now lies in the mixer for the hot and cold. I could take the faucet apart but as they are older taps, it might just be better to replace them. Thanks for the help and advice guys.
