How do I reprint text on painted metal?
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    I'm planning to repaint a couple of our appliances, but I'm not exactly sure how to get the text back on them after I do (e.g. the markings for the dials and buttons) -- is that something I'd need to silkscreen or should I try to find a service that will print custom decals? I don't want it to look cheap, but I don't really have experience with either of these -- so I don't know what would work best...
    Any ideas?
    New knobs and buttons can be had at an appliance repair shop. That's probably the best way to go.
      • 22030
      For such an application I would simply use a Brother P-touch labeler and a clear-backed tape with black lettering so the background would show thru. If you don't already have the tapes they're about $10. Clean the panel well and they'll stick fine but the outline of the tape will show... but good enough for the utility room...
      Except for a sharpie marker about everything else would take some artwork - you could measure and layout on a computer CAD program the you would have to go to a service to have a silkscreen made (best for multiple panels) or a label decal made. Which you would apply to a empty panel (remove all knobs the remove the controls from the back). With a silkscreen you'd have to pay to make the silkscreen then apply the silkscreen and paint to a flat (meaning again you have to take all the stuff off of it). Maybe it has to be brought to the place where they do the silkscreening so you'll have to disassemble your appliance..
      Yeah, P-touch is looking better....
      • Lonnie in Orlando
        • 649
        • Orlando, FL, USA.
        Disclaimer ...
        I have absolutely no idea about the following. I saw it in a post on the Antique Fan Collectors forum. A member used "Micro Mask" to mask off areas for painting. It's kinda like liquid masking tape. So you must cut the area to be pained manually.
        http://afca.mywowbb.com/forum1/14433.html
        Here is info on Micro Mask:
        http://www.microscale.com/Merchant2/...roduct_Count=2
        While I was reading about Micro Mask, I also saw printable decals. Maybe you could print them for your appliances. Clear coat for protection from wear.
        http://bare-metal.com/Experts-Choice-Decal-Film.html
        - Lonnie
        • gjat
          • 685
          • Valrico (Tampa), Florida.
          Go to a trophy shop and have the make new labels for you. We have them do plastic and metal labels for us. If I recal, they're less than $2 each. Different places have different methods. I believe the big cost is layou out and some will accept your layout if in the correct format.
          • woodturner
            • Jun 2008
            • 2049
            • Western Pennsylvania
            Note that you still have to cut out the letters with a knife - which is difficult to do and have it look "right" - it's difficult to be precise enough that the letters look the same and consistent.
            It's relatively inexpensive to have thin metal etched. You can print the artwork on your printer, send the file or hard copy to the etch house, and they will edge thin metal (.020"?) to make a mask. This mask can then be used for silk screening or spray painting.
            If you could find a hobbyist with a CNC machine, they could machine the masks as well.
            • Mr__Bill
              • 2096
              • Tacoma, WA
              I'm not sure it's still available but..
              Press Type. It comes on a sheet with a bunch of letters and you place it and rub it on to whatever you want type on. Used before desk top publishing for photo ready setup that went to the printer when you didn't have a LinoType machine.
              If you find it after setting the type give it a clear coat to protect it.
                • 2808
                My apologies for not having the time to explore this more indepth... but just a quicky:
                Years ago, 3M used to make a very nice product called "Image-N-Transfer".
                Basically it was for making your own rub off decals. It required a photo negative (you get one from your local printer) and then light exposure through the negative against the I-N-T and then a splash of the chemical and a little rubbing and you have your image. You then rub it off onto your panel or whatever and then a little shellac or laquer to fix it and you were set. The I-N-T was available in common colors, including black, white, red, green, blue, and yellow, as I recall.
                Like so many other graphic supplies, I am not sure this is still available. It used to be a nice product for making model train decals.
                I did do a Google for "Image N Transfer" and got several hits. I unfortunately don't have time to investigate (my apologies)... but I did look at this: http://www.mat.uc.pt/~pedro/ncientif...e-delcals.html
                It appears to discuss several applications.
                I hope this helps,
                • phrog
                  • Jul 2005
                  • 1796
                  • Chattanooga, TN, USA.
                  To make a decal for a model airplane, I used something similar to what Lonnie in Orlando mentioned, Clear Decal Paper for an Inkjet. You can see it here: http://www.micromark.com/SearchResul...chPhrase=decal or here: http://www.micromark.com/CLEAR-DECAL...EETS,7942.html
                  Unfortunately, since it is clear, you can't use white unless your printer has white ink. They also sell white decal paper but my decal didn't need white to be accurate. You have to be careful when cutting out the white decal after finishing your printing.
                  I scanned an old torn decal into my computer, used Photoshop to "repair" it, and then printed to the clear decal paper. This made a "new" decal.
                  I don't know how this would stand up to wear and tear on an appliance, however.
                  Richard
