For Minnesota with fescue and/or bluegrass an electric might work OK. For the south with a spreading creeping grass, I don't think it would be worth trying. I've lived in the north with the grasses I mention and am now in the south with Bermuda and a little Centepede in spots where it has invaded. I think a gas powered mower is the only realistic option unless you have a VERY small lawn and like a workout (a reel type will be a workout).
With respect to maintenance of gas powered it is pretty minimal. Sharpen the blade is a good idea but mine is on it's third year at the moment (it needs sharpened, I admit). Changing the oil is a good idea but I haven't done that in more than a year either. I check the oil and make sure it is full before filling with gas. Every few years you might have to clean out or replace the air filter and replace the spark plug but it seems like those go 3-5 years. My self propelled mechanism seems like it only works on one side but it does not bug me enough to mess with it yet. I may just give it away and buy another one.
For a small yard you don't even need self propelled so you should be able to pick up a mower under $200 and it should last 10 years - more if you are better about maintenance than I am. It still seems like the best option for most people. They have really improved the starting. No priming and mine starts on about the third pull cold, usually first pull hot. When I bought it maybe 7 years ago it started first pull hot or cold. Probably time for a tuneup. I'm not sure I've ever checked the air filter or the plug.
