motors/electronics on a small engine are not designed to take the amperage of a car system. This is also true of motorcycles. If you have to boost your battery, use a charger set to 10 amps.
If there is power available where the mower is stored, invest in a Battery Tender Jr. It is a float charger that will shut off when the battery is charged and turn back on when it senses the voltage is to low.
So got a spiffy new float charger that at least said the battery was charged after several hours of charging. Still won't turn the engine over, although it tries. It does work when the engine is warmed up. Manual for the mower specs 190 CCA, my battery says it is 243. Is it possible that I just need a battery with more oomph on a mower that is 5 years old?
Do you mean pull the spark plug and try to start it and it should go to TDC? If it does then it is a valve problem? I am going to change the plug anyway.
