All About Primer
    All About Primer
    The OSB that is on my shop walls inside is going to suck up paint/primer like a big 'ol slurpee. So, was killing time at HD today and they have Olympic interior drywall primer for about 80 bucks for 5 gallons and another interior PVA primer for half that. I got curious what the difference was and which one was best and decided to do some research. I found this writeup which is pretty good:
    http://www.finehomebuilding.com/PDF/Free/021161060.pdf
    Translation for me is I won't buy the higher-cost drywall primer again, even for drywall but will stick with the PVA, at least for walls.
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    I use 2 products for priming. Gripper or Kilz. Kilz is easier to work with and Gripper sticks to anything & is harder to cleanup. Normal drywall job = Kilz. Smooth items like pegboard or hardboard = Gripper.
    • stormdog74
      • Mar 2007
      • 426
      • Sacramento, CA
      Nice article - thanks.
      • herb fellows
        • New York City
        +1, nice article, thanks.
          • 22109
          what, a primer on primer?
            Mike, I stil use killz and will for stuff that needs to be sealed, hidden, but it costs 13 bucks a gallon. The PVA primer I looked at is half that.
            • Hellrazor
              • 2091
              • Abyss, PA
              • Ridgid R4512
              Don't look at Gripper... $20/gal or $92/5gal
              BUT.. if you need paint to hold to a very smooth surface, it rules.
              • eezlock
                • 997
                • Charlotte,N.C.
                all about primer
                If you have an air compressor already in place...try this. First, seal all the osb
                surfaces with spray shellac...it really seals the surface well and makes painting
                a whole lot easier too! The paint won't be absorbed into the surface either, I have been using this method lately and wished I had discovered/ tried it years ago.
                • conwaygolfer
                  • Jun 2008
                  • 371
                  • Conway, SC.
                  Primers
                  I once had a rental property. The tenant was there for 18 years. He smoked heavily and never put a drop of paint on the ceiling or walls. When he finally moved out, the living room ceiling was almost brown from smoke. I used 3 coats of Kilz, but the smoke kept showing thru. A contractor friend told me to use Zinzer Bullseye Primer. That did the trick. I have been a fan of it ever since. Not sure if the first 3 coats helped, but I never bought it again and never had a problem with Zinzer. So in my opinion, it is the better of the two.
                  Thanks,
                  Conwaygolfer
                  • billwmeyer
                    • 1868
                    • Weir, Ks, USA.
                    Paint & Primer
                    While we are on the subject of primer, I am going to paint my house next spring. HD has a combo house paint and primer. Has anyone used this? It sounds like a good way to go if this is any good. I plan on two coats.
                    Thanks.
                    • Salty
                      • 690
                      • Akron, Ohio
                      Is that the Zinzer primer that is made from bug juice? Or is that shellac? I prefer the Zinzer for priming stained surfaces. But you still have to sand it.
                      And oh yea, the primer is in the paint theory. If it takes 2 coats anyway, which mine almost always does, are you not putting on 2 coats of paint that is too expensive to begin with?
                      • Tom Slick
                        • 2913
                        • Paso Robles, Calif, USA.
                        • sears BT3 clone
                        real shellac is bug juice. Is there a different bug juice coating?
