Permanent Structure Laws...
  • rjwaldren
    • 368
    • Fresno, CA
    Along my back shared fence line I have a 10x10 area that is covered with paving stones and a canopy. The canopy probably won't last much longer so we are looking into building a Ramada/Pergola there. The idea is to extend it to 16x10 and keep the pavers. If I sink the post does that make it permanent structure? What about if I only anchor the posts?
    Though not confirmed yet, I've heard that permanent structures require a 3 foot clearance from the property line around here. The neighbor doesn't care but the top will be visible from the main street. I already have power and water there in a way the keeps it "temporary".
    Check with your local building code enforcement authority. Definition of temporary vs. permanent varies radically between municipalities.
      There's probably two different codes to deal with. One will be your local zoning code and the other will be the building codes (more than likely the IBC & IRC International Codes). The IRC/IBC will deal with openings, proximity, and other fire related items of the structure.
      If you're talking about power and water lines there's probably an easement there as well.
      *edit I just noticed where you are from. I think most of California uses it's own state building code, not the I-codes. A quick anonymous call to your building official should get you squared away.
        Call from a pay phone from the other side of town. Wipe all fingerprints when you're done.
          No kidding
          Sometimes a call about specifics can lead to a BO stopping by the site to check things out.
          • rjwaldren
            • 368
            • Fresno, CA
            I started some simple Google searches and doubt I'll get away with it legally. Even in some places where you can put a pergola up with out a permit, it's required once you talk about covering the top.
            Round here you need a permit to change out a toilet, so I'd rather not have them around just yet. But I will give them a call, sometime when my dad drops by so I can use his cell... Now that's a house the Inspectors would pop a blood vessel over.
            • BobSch
              • 4385
              No kidding
              Just having a truck in the driveway can do that. Mt BIL was helping me put a storm door on out patio door when a Pinto pulled into the driveway. I walked down and the guy asked where [an address two doors down from us] was. I pointed down the street and as he was getting ready to pull out he casually asked what we were doing. Never identified himself as a city inspector, but the backseat full of blueprints pretty much blew his cover.
              Bob
