The plans for the stair addition to my porch were approved. I want the
four posts to sit on metal anchors buried in the concrete. I don't want the
posts buried in the concrete footers.
It's not a big deal for the longer posts closer to the house. I know I can
prevent them from swaying. My concern is with the bottom 2 posts. There
will be three stair stringers--two that flank the outside of each post and one
down the middle. The middle stringer will be anchored to a concrete footer.
If the bottom riser is bolted to the two corner posts and also attached to the
middle stringer, will I have to worry about the posts/rails swaying? By code it
needs to withstand a 200lb side load but I want that thing to be as rock solid
as possible for my own ego.
Thanks,
Paul
Thanks,
Paul
