Is Super Glue the way to go, or some sort of epoxy or resin? Wifes favorite "Magic Bullet" blender - the main plastic gear that intercepts the blender bottom cracked in 3 clean pieces. Pretty lame that it is plastic to begin with. Anyways, really dont want to spend $60 for replacement (guess I could look into replacement part worse case)... BTW - this thing is great! Any ideas? Thanks
Best glue to fix plastic?
Probably good advice there. I glue up polycarbonate using solvent, but the kicker is I dispense this solvent through plastic syringes. It has no effect on that plastic at all. You need to be sure that the epoxy says it is for plastics as well as other items. Most do not include plastics. Plastics is a widely encompassing term and not always very accurate.LeeComment
I can't remember which forum that I got this from, or who first posted it, but try This To That .From the "deep south" part of Canada
http://richardspensandthings.blogspot.com/Comment
There are a ton of plastic types. if you can get a solvent based (aceetone-based liek Duco cement or model airplane glues) glue to work, then that provides the best solution.
www.this to that.com is not much use, they also say there's too many kinds of plastic.Loring in Katy, TX USA
what about model glue? most plastic "glues" including model glues, PVC, and ABS cements actually melt the plastic which makes a superior bond. as lee mentioned MEK, tolulene, acetone can work very well for gluing/melting plastics together.
If you use epoxy keep in mind that the slower the epoxy sets the better adhesion/bond it creates.Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas EdisonComment
Footer Ad
