Bonding PVC to HDPE- or alternatives?
  • Gator95
    • Jan 2008
    • 322
    • Atlanta GA
    • Ridgid 3660
    I've got a 55 gallon HDPE container left over from the plant that I'm planning on making into a rain barrel to fill off the gutters. Walls are about 1/8-3/16 thick or so I think. Trying to decide what the best way to connect a faucet to the bottom of it.
    Offhand, I was thinking of just drilling a hole the size of 3/4" PVC pipe into the side of it near the bottom and then inserting the pipe in the hole and putting a faucet at the end of the PVC pipe (so many different valve possibilites there... doesn't really matter which one I use).
    Was thinking of trying PVC cement to bond, but wasn't sure it would take with HDPE. Other alternatives are epoxy, epoxy putty, or silicone caulking. The barrel would be outside and pressure will be just the head pressure of a 55gal barrel filled with water.
    Any thoughts?
    • 22098
    I did a google for Glue HDPE to PVC
    http://www.innerduct.com/products/hdpe_glue.php
      Any thoughts?
      I just bought two old barrels today so I've been reading up on this, too.
      This is what I came across which is what I'm planning on doing. Instead of
      gluing anything together, I'm going to get a thread tap from Harbor Freight
      and screw the spigot in. Finally, I will caulk around the threads.
      http://www.cityofbremerton.com/conte...ainbarrel.html
        I think I would get a threaded PVC male fitting and another female fitting then drill the hole, insert the male fitting and screw the female on to hold it in place. Plumbers putty and/or a rubber washer would prevent leaks.
        • gearbuilder
          • Dec 2007
          • 22
          • N.W. Indiana
          If the lid to your drum is removable you might be able to use a through the wall fitting. If the lid doesn't come off I'm not sure how you would tighten the fitting.
          http://www.mcmaster.com/ctlg/DisplCt...MainWidth=1068
          Jamie
            Jamie
            That's the boat I'm in. The tops of my barrels are permanently on. If they
            weren't, I'd definitely go with the male/female fittings. I guess I could cut
            the lid off, but the lid provides so much rigidity. That's why I'm going to try
            the tap and screw-in spigot method.
            Paul
            • gjat
              • 686
              • Valrico (Tampa), Florida.
              You have to have some sort of opening for the down-spout, so I'd go for the male/female fitting. What you need is a bit of inginuity to get the male part of the fitting in the hole. For example, a piece of stiff wire long enough to feed from the top to the hole near the bottom. Slide on the male part then attach a block to the end of the wire that won't go throug the male. You can then pull it tight from the outside, hold it and thread on the female. Don't forget to add silicone to both sides of the hole.
                As others have also advised I'd use a bulkhead fitting http://www.dultmeier.com/search.asp?...njo%20Bulkhead
                Since you need to cut a hole in the top for the in you will have access to the inside. The plastic barrels that I've been around were at most 1/4" thick. I'm skeptical on cutting pipe threads in that thin of a wall and keeping it from leaking. I've not any experience with the glue that Loring posted a link to but it might be worth a look.
                  Definitely don't listen to my first plans on tapping threads and installing a
                  brass spigot. I'm glad I lost my eBay auction on the tap. While one website
                  used this method, another warned against it because when the temps
                  change, the barrel can crack around the hole. The bulkhead fitting as the
                  others suggested is the way to go.
                  This is an excellent YouTube video of the installation. The guy also figured
                  out how to install the bulkhead without having to cut the whole top off.
                  http://www.youtube.com/watch?v=nvWginV0el4
                  He doesn't say what size bulkheads you need, though. I looked at several
                  bulkhead fittings online and some reference the size of the hole you need to
                  cut to pass the bulkhead through while other reference the size of the ID
                  hole for the spigot but none of them explicitly say which is which. Argh!
                  EDIT:
                  Found another one where you can use the bung as the spigot source. No
                  bulkhead needed:
                  http://www.youtube.com/watch?v=MGFDlkJOdaM
