I have a 10-year-old Kenmore water softener that stopped working recently. I first replaced the motor ($75!) that puts it through its cycles, and it seemed to be working (i.e., pumped) but didn't use up the salt. So I first cleaned the venturi, put resin cleaner in the system, and then replaced the venturi assembly when it wasn't improved. Still no salt usage, although it pumps water around, though more out of the system than between outer tank and resin tank. I used the online trouble-shooting guide, which got me to a "call an expert" conclusion.
I can't see spending $450-$550 on a new water softener when this one seems so CLOSE to working! Anyone have ideas on how to proceed?
If I do need to get a new one, what's the difference in the 30,000 grain vs 40,000 grain models besides the $100 or so in cost at HD? Would the cheaper one just end up using more salt and flushing water, whose cost would offset the lower startup cost? We have a 4-person household, with no unusual demands on softened water.
