Outlet Boxes set too deep
  • wareagle
    • 66
    I installed some new outlets in my basement before having the drywall installed. Today when I finally got around to putting on the cover plates, I discovered that some of them are set too deep behind the drywall and the standard plates won't fit.
    Any suggestions on how to fix this problem? I have 2 small kids who will be running around down there and I want to make sure the outlets are properly covered.
    An adjustable mud ring may be of some help.
    • pecker
      • Jun 2003
      • 388
      All you need is a spacer to hold the outlet out further from the box...assuming you're only talking a quarter inch or so. You would have to remove the outlet, put the washers or other spacer over the outlet mounting screws, then re-install it. You shouldn't have to disconnect any wires...just shut off the breaker first.
      • Hellrazor
        • 2091
        • Abyss, PA
        • Ridgid R4512
        Electrical box extenders are available from most building supply stores.
        • steve-norrell
          • 1001
          • The Great Land - Alaska
          Here are a couple of products that I have used, These are from Lowe's, but they can be found in almost any hardware or electrical supply outlet, including the Borg.
          http://www.lowes.com/lowes/lkn?actio...CRD&lpage=none
          http://www.lowes.com/lowes/lkn?actio...-04&lpage=none
          Regards, Steve
          • Mr__Bill
            • 2096
            • Tacoma, WA
            A few turns of copper wire around the screw will act as a nice spacer, easy to adjust too.
            • wareagle
              • 66
              Thanks for all the feedback guys. I found some of the spacers at Menard's and they worked perfectly.
