Hey All;
The floors in my girlfriends house have settled, and continue to. Looks like about 1" over ten feet. After crawling under the house, there were no failing joists or support beams. The support columns also looked good, and did not appear to be failing. From the look of things, it is the result of the ground under the house settling.
What I would like to know, is what precautions and corrective measures can I take to correct, or at least stop the problem? The house should not be jacked to the proper height all in one move, should it? And what type of support do I need to put in place - IE, pouring a concrete pad's, floor jacks, etc?
Thank you,
Chadwick
Thank you,
Chadwick
