Armored or not?
  • gsmittle
    • 2793
    • St. Louis, MO, USA.
    Armored or not?
    I'm about to install a generator transfer switch. The switch itself is near the breaker panel, of course, but the junction box for the generator power is on the other side of the house.
    What I'm wondering is if I should go to the extra expense of using armored (BX?) cable instead of Romex for the stretch from the junction box to the transfer switch. The only part of the cable to go outside is less than six inches--the rest of the run is in the basement along the floor joists to the breaker panel.
    Any thoughts?
    g.
    Smit
    "Be excellent to each other."
    Bill & Ted
    This has to be pretty big wire so the difference in price is probably significant. I would put the part outside in conduit and not pretct the stuff in the floor joists. I don't see why this would be different than other wire (just bigger). I did not look at my code book, however.
    • Hellrazor
      • 2091
      • Abyss, PA
      • Ridgid R4512
      Ugh.. brainfart. I think duraflex is the name of the stuff we use at work to go from an exterior box and into the building. It is a 3' section of non-metalic flex conduit. I know BORG usually carries it. Otherwise you will need to use THWN in conduit or other waterproof cable. Romex/etc is not rated for exterior exposure.
      Do you need to have this inspected?
      • gsmittle
        • 2793
        The cable is 10/3 solid copper, per the transfer switch docs. My initial thought was running the cable through conduit from the exterior box into the house. Then I made the mistake of looking at the BX. Of course, once I finish this, I'll never lose electricity again!
        I should probably have the work inspected. I'm trying to do it myself and save a few bucks, since the installation is pretty simple.
        g.
        Smit
        Bill & Ted
        • reddog552
          • Dec 2006
          • 245
          • Belleville Il.
          • Bt3000
          Romex
          romex is fine in joists. just before you go outside install a 4" j-box.run 3/4" flex pvc to unit.
          The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
          • LJR
            • Jan 2005
            • 136
            On the outside part of the run the romex has to be protected from physical damage. On the inside of the house it's fine to use romex. As reddog suggests mount a junction box at the point of entry and then use conduit from there to the generator attachment. Run your romex through this conduit and box to protect it. Not necessary to run armored cable the whole way nor is the extra expense justified here. If you're really worried about protecting the wire I'd suggest doing the whole run in conduit.
            • Hellrazor
              • 2091
              • Abyss, PA
              • Ridgid R4512
              g.
              The reason I asked was... ask the inspector what they expect to see in that scenario.
