Clothes dryer: no heat.
  • Cheeky
    • 862
    • westchester cty, new york
    • Ridgid TS2400LS
    My electric dryer will run/turn, but there's no heat introduced.
    i checked the circuit breaker. i have 220 coming into the dryer...checked that.
    i have the dryer apart, and have checked continuity of the following:
    thermostat
    thermal cut-off
    heating element
    they all register ok with my multimeter.
    is it possible for the heating element to register continuity, but still not work?
    Pete
    • 22060
    Your heating element should be well below 20-30 ohms - you need to check resistance, not continuity.
    I imagine that the timer has a switch which applies the heating during certain periods of drying; the thermostat (in series) just regulates the temperature.
    so if the thermostat is ok then probably the main heater on-off switch which would be part of the timer is out.
    I'm not a real appliance guru, don't know of the switching is done in the timer itself (would then have to handle 10+ amps) or in a relay controlled by the timer.
    • mschrank
      • Oct 2004
      • 1130
      • Hood River, OR, USA.
      RepairClinic.com has helped me before. Here's a link straight to your problem:
      http://www.repairclinic.com/0088_8_1.asp#Level1_2
      EDIT: I just read their recommendations, and it sounds like you either read the same thing, or you already knew what you were doing. I'll bet Loring's right.
      • Cheeky
        • 862
        • Ridgid TS2400LS
        You're right on both accounts, the heat relay switch (below heat selector) is fried. Opened up the panel, after taking the friggin drum out (darn dryer doesn't have a rear access panel), and the switch was partially melted and black dust was abound.
        that site is fantastic, just wish i checked the control panel 1st before the rest of the fuses, etc. next time, i'm going to check the console 1st
        Pete
