2-Cycle Engine Maintenance
    Since I can't find the manual to my string trimmer, anything I need to do beyond changing spark plugs? That is all I've ever done in 7 seasons.
    try going to the manufacturers website and finding the manual or at least a manual for one similar to yours?
    Since the oil is in the gas, I don't recall that there was much to do.
      Don't they still have a air filter over the carb that should be cleaned? I know my Lawn Boy does.
        I never do anything to my chain saw and weedwhacker. My boat motor plugs the low speed circuit of the carberator if I do not run the gas out, however, so I try to remember to do that. I change plugs or bang the worst part of the junk off the air filter if it refuses to run.
        • Garasaki
          • Sep 2006
          • 550
          Air filter.
          Might have a fuel filter but I doubt it.
          You could always rebuild it if you really wanted to. Or change the rings. Lawdy that'd be easy on a weedwacker...
          Just make sure you give it fresh, good oil, and don't use ethanol gas (perhaps a myth? I'd rather not take a chance), and it should be pretty good.
          -John
          -Henry Blake
            Loring, tried that. It is a Ryobi 790r. IF there is a user manual I can't find it. I figured a 2-cycle engine is a 2-cycle engine and there isn't much beyond spark plug and air filter. It runs ok, just wondered if there was anything I should be doing
            • MikeMcCoy
              • Nov 2004
              • 790
              • Moncks Corner, SC, USA.
              • Delta Contractor Saw
              It may not make any difference but I add Stabile to everything from generators on down to the edger (including gas in the can) and have never had a problem.
              • L. D. Jeffries
                • 747
                • Russell, NY, USA.
                Some of the trimmers, like mine which is a STHIL, has a fuel filter in the tank, on the end of a small plastic hose that feeds gas to the engine.
                RuffSawn
                • doubleoonothing
                  • Sep 2007
                  • 6
                  • On a small Farm in Santa Rosa, Calif.
                  • 1950 vintage Craftsman
                  2 cycle care
                  First, crokett, thanks for the Bamboo and dato tip, now to you and your 2 cycle interest. On the farm a weed wacker is a well used tool, I trim about 2 acres every year around equipment and such, I have had nearly every make in my hands. Rarely do I put them away with fuel in them, I run them dry. Like you said, air cleaner & plug are the big ones, if you want to go above and beyond, you can visit your marine supplier and get "Fogging oil" and follow the directions. And about gasohol (less than 10% alcohol), it is helpful in reducing carbon buildup which causes loss of power in the engine, but that shouldn't be a problem if you strictly adhere to oil mix ratios.
                  • Jim Boyd
                    • 1766
                    • Montgomery, Texas, USA.
                    • Delta Unisaw
                    Here is something to help ya out.
                    http://www.odref.com/pdf/Ryobi/
                      Mostly a repeat of the above. The manual on my echo says to empty the tank, start the engine and let it run out of gas before putting it away.
                      As to maintenance, keep the air filter clean and change the plug once a year. There is normally a strainer type filter on the end of the gas line in the tank that may rarely need cleaning. The only other thing to watch is the fuel lines. They are plastic tubing and will eventually crack. When you have a leak, replace all the lines.
