fluorescent slow to light
  • wayno
    I put a fluorescent bulb in dining room and when I turn it on it
    comes on gradually. Once befor same place I put a dimmer
    switch on this bulb when it was incandesent and it was very dim on
    full power so changed back to reg switch.
    Anyone have answers?
    Thanks
    wayno
    • 22056
    the obvious thing is to get a voltmeter and see if the light fixture is getting full voltage when its on.
    this of course requires basic electric skills in operating a voltmeter opn a live circuit and knowing where to measure in the light fixture w/o electrocuting yourself.
    If you don't know how to do that then you need an electrician.
    • DaveS
      • 596
      • Minneapolis,MN
      Originally posted by wayno
      I put a fluorescent bulb in dining room and when I turn it on it comes on gradually.
      Is it a screw-in compact fluorescent?
      The ones we are using come on pretty dim and then get brighter after 30 seconds or so.
      If it "heats up" to normal brightness in under a minute, I think that is normal.
      • stormdog74
        • Mar 2007
        • 426
        • Sacramento, CA
        This is true for the older ones, but the newer ones seem to have fixed this. I found the older ones annoying, but the new ones are just like a "normal" lightbulb. I think the package for the newer ones said something like quick starting - that's not it, but you get the idea.
        • Jeffrey Schronce
          • 3822
          • York, PA, USA.
          • 22124
          Maybe its the better ones versus newer ones? I got a new pack the other day in an effort to take a stab at reducing my $330 power bill and they are very dim and takes a few minutes to "warm up".
          I need to check on the ones you are talking about because these are not cutting it.
