I have a plumbing leak or leaks that I would normally just fix myself, but the water is coming from plumbing that is located behind an HVAC duct that is wrapped with foil insulation. I can barely see where the leaks are coming from if I shine a light behind the duct. What I am trying to decide is: do I remove the duct so I can get to the leaks, repair the problem, and then replace the duct, or should I call a plumber/HVAC company and pay what I figure will be a high price to fix it? I have two air systems and this is the one that heats/cools the upper level of my split level, so I could stand to have that system down for as long as it takes to do the repair. Any suggestions?
LCHIEN
