Advise on choosing an insulation contractor?
  • DaveS
    • 596
    • Minneapolis,MN
    I am in process of getting quotes for blown in insulation.
    Aside from getting it deep enough, to a uniform depth, and making sure the soffit vent trays get inserted correctly.... is there anything else that makes for a "good" insulation job?
    Any thoughts on cellulose vs. blown fiberglass? Any opinions on which is better?
    I have fiberglass up there now - can I put cellulose over the top of it?
    Has anyone here ever done their own insulation?
  • jking
    • 972
    • Des Moines, IA.
    There's no reason you can't put blown-in over fiberglass batts. I can't think of anything else to look for. Maybe ask about clean up. If the access to the attic is through the house, I would want to know if they are going to clean up most of the mess when they are finished.
    • jAngiel
      • Oct 2003
      • 561
      I did my own in the addition that we did a few years ago. There's not too much to it but it's definitely at least a two man job. Dusty to so wear long sleeves, long pants and a mask or respirator.
      Around here most places will give you to blower for free to use if you purchase at least ten "bales" of insulation.
      James
      • messmaker
        • 1495
        • RICHMOND, KY, USA.
        • Ridgid 2424
        Mke sure you remember the job at tax time. It will help you get a nice tax credit that will help offset the cost. It must be done in 07 as it stands now.
