How to repair a sticky door after painting?
  • gychang
    • 188
    • Sacramento, California
    • none
    Finished painting entry door from garage into the kitchen 2 months ago with latex paint and continues to stick. (have to pull on the door knob hard).
    Is there an easy cure?, WD40?
    thanks,
    gychang
  • siliconbauhaus
    • Dec 2006
    • 925
    • hagerstown, md
    sounds like it needs to be shaved a bit because of the paint buildup.....but you could try a bit of past wax and see if that helps
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
      • 22012
      or wait for a cool, dry day, the door will shrink a little as heat and humidity make then expand.
      Shoulda fixed it before painting. Yeah, I know, it didn't stick then.
      • eezlock
        • 997
        • Charlotte,N.C.
        repair sticking door
        Probably the best solution is to take the door down, remove the hinges and
        shave/plane a couple of thousands off that side and re-install the hinges
        and rehang the door, that should cure the sticking problem. eezlock
        • gychang
          • 188
          • none
          best solutions seems like little work. thanks.
          gychang
            thanks,
            gychang
            You didn't say where it was sticking (if you know).
            • gychang
              • 188
              • none
              assuming the door is "larger" due to addition of latex paint...
              gychang
              • gychang
                • 188
                • none
                Originally posted by Jay Keller
                you the same guy that cant figure out how to get out of the CHINESE HANDCUFFS?
                what?, no. gychang
