Paul
Now you produce the mystery brick. Well, I still fall on the idea of Tapcons, but limit their depth to wall thickness of the brick with relation to the hole, It wont matter if the Tapcon penetrates through the hole, as they are shaped like a machine screw having a straight threaded shank. They thread into a smooth hole. Another fastener is called a sleeve anchor. Just drill a hole and push through and then tighten the nut. It expands and doesn't need much to hold in place. Here again, the depth can be figured. As for the head (nut), it can be outside of the screen assembly. These are available in many materials, and sizes, and are used commonly for aluminum screen enclosures.
Dee Dee Dee
