LOML wants me to turn our back patio into a screened room to keep the bugs out most of the year. Basic "wall" construction is easy - I've done that before - but only indoors. Can y'all help with some questions? Patio pictures attached.
1. I was planning on using composite "wood" for the construction, mainly for low maintenance. Think that's OK, or would pressure treated lumber be better?
2. Attaching the sills to the in-place concrete patio. Anchors no problem. But do I need to put anything (construction adhesive, caulk, etc) under the wood?
3. Attaching the uprights to the brick (probably hollow ) columns: a) with what? b) attach whatever anchors to the brick or the inbetween concrete c) what do I use for a seal between the wood and the brick column since there is obviously an "opening" between the bricks, and wood flat against the column would leave a gap - caulking, foam weatherstripping, or?
4. Attaching the uprights to the house itself - pretty much the same questions as #3? Same method, or?
And, of course, anything else I need to know??? Thanks in advance!
