Filling gaps in plywood floor??
  • lago
    • 473
    • Lago Vista, TX.
    My shop has 3/4" PT plywood for floor. For whatever reason, the contractor left gaps between each piece, 1/8" to 1/4" wide. Probably because this part of the house is in the 100 yr floor plain. Anyhow, there are 8 joints about 20' long that I want to fill in.
    I have covered the gaps with duct tape but it is wearing out and I want to make a more permenant fix. I used one tube of caulk and it did not go too far. It may take another 15-20 tubes to finish.
    I do have access to the floor underneath so I can put duct tape or 1/4" ply to close the gap. I am just looking for something that could be used to fill the gaps.
    Right now, I can't find any large tubes of caulk, just the 10.1 oz tubes and cheapest is about $2/ea.
    Any suggestions?
    TIA
    Ken
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    Tommy on Ask TOH filled gaps in a 100 yr old floor with rope.
      • 22034
      what's the purpose of filling the gaps?
      Dust and dirt trap?
      Wheels go clunk, clunk when you move tools around?
      Visual?
      Don't they have some liquid, self-levelling stuff for filling driveway cracks?
      Use that plus the rope?
        I think I'd do rope plus bondo. Although not sure how flexible bondo is when cured. Not sure how much that flooring is gonna move.
        • Thom2
          • 1786
          • Stevens, PA, USA.
          • Craftsman 22124
          perhaps the joint compound used for leveling floors and filling gaps prior to installing vinyl flooring would work??? .... IIRC, when I did my kitchen floor, a box of this stuff was pretty cheap and would go quite a long way.
          • lago
            • 473
            • Lago Vista, TX.
            I was thinking of using something to reduce the space and then fill in with caulk. I didn't think about using rope but that is a good idea.
            The duct tape ('guy tape' as LOML calls it) is showing wear & tear. I need to keep the gaps closed to keep sawdust, SMALL parts, and stuff from falling thru. One of these days I might want to also paint the floor.
            Ken
            • ivwshane
              • 446
              • Sacramento CA
              What about expanding foam?
              • jhart
                • 1715
                There's a product called "Water Putty", I believe, that can be found in big box and hardware stores, that used for leveling floors, filling cracks, etc. I would think that it would work well for this purpose. I have used it numerous times for leveling under new flooring. Comes in various sized cans and not that expensive.
