Is there any reason why I couldn't use the outlet box of a bathroom cieling fan as a junction box? The wire going into the box is a 14/2 and the wire I want to go in to it and connect with a similar wire is also a 14/2.
Wiring question
ivwshane, the only reason it wouldn't work is because the junction box may become too full with wire and connectors. There is such a thing as a box fill calculation which tells how many wires and devices will fit into what size box.
From your description it sounds like you're talking about the little sheet metal junction box that's actually part of the fan enclosure? I've seen some of those which are really small and some of them have plenty of room for another splice. -
I should have added that a number 14 conducter should have 2 cu. in. of space in the junction box. Thus, if you have two 14/2 with ground you will need 10 cu. in. of room. That doesn't count wire clamps or whatever else is in the box.
http://www.selfhelpandmore.com/homew...fill/index.htmComment
I wouldn't. If the day comes that you have to replace the fan you will have to move all the wires that went to the box.Sometimes the old man passed out and left the am radio on so I got to hear the oldie songs and current event kind of thingsComment
