A little old lady wants me to build a cover over her 2nd story deck, approx. 16 long by 10 deep. She drew up the plans supporting the two outside corners with 4 X 4s and the rear rim joist bolted to the house under the eaves. She visualized using 2 x 6 x 10 for the rafters, attached to a doubled 2 x 6 x 16 with a steel flitch plate bolted between them for rigidity. The roofing material is to be a PVC sheet product she described as Palruf PVC. It sounds to be a lightweight transluscent panel. She says it is not corrugated. She is spacing the rafters 16 OC using saddle hangars. I told her that the flitch plate will probably be rather expensive and I dont know for sure where to purchase it. She would prefer not to have a support post in the middle of the front rim joist. Could just a doubled 2 x 6 span 16 in this installation without sagging?
Will This Sag?
Doubled 2 x 6 will sag on a 16' span. Usually the distance of the span will dictate the width of the beam therefore a 16' span will require a 16" wide beam or a 4x16x 16' or 4x 18x 16' beam. Now-a-days the lumber/beams are cut from young trees and do not have the strength like old growth lumber/beams. I have seen 4x20 beams sag on a 20' span, they don't have the carrying power like before. Or you can go with an engineered beam/truss for the span and weight it will support. I'm not a structural engineer, just my opionion/experience building homes. I would have the lady consult an structural engineer for this before taking the job and risk having a recall. -
I take it you guys don't need building permits in Alabama?
sounds like a fine idea.Originally posted by jabeI would have the lady consult an structural engineer for this before taking the job and risk having a recallLast edited by 91FE; 09-15-2006, 07:04 AM.I like Wagoneers too. Hey...they've got wood
my old 2 story deck is made of either 2x10 or 2x12 framing spaced 24" on center. The largest unsupported span is 12foot and it doesn't sag with with 5/4 decking on top of it. This deck is nearly 20 years old.
I think for what she is trying to do (minimal weight load, no snow) 2x10's would work. 2x6's might sag a bit.Mike
Lakota's Dad
If at first you don't succeed, deny you were trying in the first place.Comment
@x6 will indeed sag. I would go with a minimum doubled 2x8 with good crown. 2x10's are actually more expensive than 2x12's most places. 2x12's are very heavy and may sag some too. I think the best bet, since the roofing is so light, is to go with doubled 2x8. I have a doubled 16' 2x8 span accross my living room that I built. No sagging after 10 years so far.
You do need a permit for some things. This would be one of those things, unless there was an existing roof.
Getting a permit is just a matter of submitting a drawing of your intentions in this case. Then pay for it. All done in about 30 minutes where I live.LeeComment
