Shed Construction
    Shed Construction
    Got a friend who is planning to build a shed from scratch and is using the 16" OC 2 x 4 type construction. Any comments on using screws 3" exterior coarse thread instead of 16d nails. This includes screws instead of nails for rafters.
  • newbie2wood
    • Apr 2004
    • 453
    • NJ, USA.
    May be overkill for a shed but will definitely work very nicely. Make sure screws are galvanized.
    ________
    Kameronsexy
      It would work but unless you are in an area subject to hurricanes or high winds, it seems like a lot of overkill.
      • Hellrazor
        • 2091
        • Abyss, PA
        • Ridgid R4512
        Nails... screws are not code compliant.
        • wardprobst
          • 681
          • Wichita Falls, TX, USA.
          • Craftsman 22811
          The problem with screws in this application, besides cost, is shear strength. Nails have much higher shear strength that screws in these types of applications.
          HTH,
          DP
          www.wardprobst.com
          • Doug Jones
            • Oct 2004
            • 332
            • Indiana
            • Delta 36-444
            Easier to take down, should he ever move.
