SITUATION: We have a front to back split-level home, so really the house is kind of like a two story home but the front entry door and 2nd living room are in-between the top and bottom floors. I would like to raise the floor of the 2nd living room up 4 ft so the floor would be the same height as the upper level in the house. I don't think this should be a major ordeal as there is already a floor there (it's just 4 ft to low) and the existing space under the floor is a framed in sub-basement. I know I'd have to re-work the air return vent, heating/cooling vents, electrical outlets, etc but these items are already there - they'll just need to be raised or moved. I would have to figure out something for the windows as raising the floor 4 ft would cut the windows in half but I can sub-contract out this part of the job.
QUESTIONS:
Does this sound like a do-able plan?
Are there any items that I'm forgetting about?
Would I have to remove the existing floor or can I frame in a new floor on top of the old floor?
Would it be more structurally sound to build the new floor up from the sub-basement to the new height and eliminate the exisitng floor?
If I run new joists across the room then how would I tie them into the exterior wall studs? There is a header running down the middle of the house so I could use joist hangers to tie one side of the joists to - can't I?
We received a decent quote on the whole project but we haven't been able to get ahold of that contractor for the last 3 months. I do have his detailed quote though so I know approximately what materials to buy
Any advice would be appreciated, thanks.
QUESTIONS:
.Any advice would be appreciated, thanks.
LCHIEN
