Water treatment
  • ted van halen
    • 76
    Water treatment
    My new 4" well is supplying water w/ enough iron to stain clothes, tubs, fixtues, etc. We've had it tested by culligan & our local DHEC. There's some hardness in addition to the iron. Any advice about what sort of system? Culligan wanted $3K for a system to treat it.(ouch!!!)
    TIA
    Ted
  • Warren
    • 441
    • Anchorage, Ak
    A filter, (30 microns) in front of a soft water system cost me around $1200 installed with a pressure tank 15 years ago, up here. I just used a local plumber to install the unit. Depending on the access to your inflow and electric, installation shouldn't take more than an hour. Check the big boxes for equipment and also get some bids from local plumbers. Even after 15 years 3,000 seems high to me. Where 'bouts are you located? If you've got a lot of new home construction going on in your area 3,000 might be what the market will bear.
    • Crash2510
      • 830
      • North Central Ohio
      we had very high hardness and alot of iron so we intalled an iron eater infront of a water softner and it seemed to work very well
      Phil In Ohio
      The basement woodworker
