I installed a couple of automatic timers for my outside lights. They are the kind that replace the light switch. One light is fine and the other has a slight, but noticable flicker about every second. I rechecked the wiring, but it is still doing it. Am I missing something? or do I have a bad timer?
Flickering Light
Flickering Light
\"Experience is the toughest teacher. You get the test first and the lesson later.\"Tags: None -
Switch the Automatic timers (new switches) and see if the flicker follows the Auto switch.
If the flicker follows the swap, then the chances are that the Automatic Timer/Switch is bad.Stop thinking why you can't and Start thinking how you CAN!
George -
Did you check the wires to make sure they are clean, and no coating is piniched / blocking a good contact. Many times I will cut the end off, and strip the coating back for a new clean end.Originally posted by havighurstI rechecked the wiring, but it is still doing it. Am I missing something? or do I have a bad timer?Ric
Plan for the worst, hope for the best!Comment
Sounds like the timer to me.Jon
techzibits.comComment
