New carb on a Honda small Engine
  • jnesmith
    • 892
    • Tallahassee, FL, USA.
    I took my pressure washer into my neighborhood small engine repair shop. It apparently needed a new carb. $95 for the carb, and supposedly 1 hour to replace it, at $60 per hour.
    I don't know anything about small engine repair, but 1 hour to change a carb on a small engine and $60 per hour both seem high. If others agree, I intend to make an issue of it. However, I need some sort of reference, or some stats regarding this sort of repair to make a credible arguement.
    Any suggestions, or comments?
    Thanks as always.
    John
  • Jim Boyd
    • 1766
    • Montgomery, Texas, USA.
    • Delta Unisaw
    If they are using a flat rate book, that sounds about right. Not sure about the labor rate but it does not sound too far off.
    • Warren
      • 441
      • Anchorage, Ak
      Both costs sound right. The shop time is a even little lower than here.
      • jnesmith
        • 892
        OK. Thanks for the feedback.
        Looks like I'm in the wrong business.
        John
        • Stick
          • 872
          • Grand Rapids, MB, Canada.
          seems like good money, but like any business, you have to consider overhead, special tools, manuals, and such. That's a pretty reasonable shop rate actually.
          • vaking
            • 1428
            • Montclair, NJ, USA.
            • Ryobi BT3100-1
            I also would not be surprised if labor smallest denomination is 1 hour. Like with your cell phone - 5 secs gets charged like 1 minute.
            Alex V
            • Crash2510
              • 830
              • North Central Ohio
              seems like a lot of money for 2-4 bolts to remove and replace with the new.
              Phil In Ohio
              The basement woodworker
              • Crash2510
                • 830
                also a good guess is to say the carb price was marked up 20%
                Phil In Ohio
                  • 22039
                  That's probably true.
                  Repair shops generally get a good discount from the parts warehouse
                  and they mark it up, it ends up costing you the same whether you buy from the warehouse/dealer directly or thru the repair shop.
                  In a way that's fair because the repair shops buy in volume and usually have less fuss per order (e.g. returns, trying to figure out what part to buy, etc.)
